Hi Guys,
Got a problem with my 2006 9-3 Estate, 175k miles, 1.8t + Hirsch upgrade. Got in the car the other day, put key in, click as steering lock unset, turned key, nothing! Display came up "Pull key out, turn steering wheel. Restart". Long story short, Steering lock is NOT engaged, can turn wheel lock to lock, put key back in, no effect. Read up on it and at various times have tried......
Battery was a little low so, disconnect battery & re-charged, changed to my spare battery (13.8v), removed Fuse 1 & 2, locked/unlocked car, tried both keys, taken out Ignition Switch Module (ISM), cleaned and replaced, left battery out for 24 hours, changed to another ISM - all to no effect, same message displayed. Tried different key (to another saab), displayed "key not recognised" etc so assume both ISM's are functioning. Moved/bodged ISM past 'Lock' position, get "Steering Malfunction, stop safely etc", still can't turn it over. Oh and, as I can't switch the ignition on, I can't read any codes!
So my logic is this, CIM reads Steeering Lock as set but it's not!? So Lock is out of step with CIM, can I reset the steering lock so it is 'set' and hopefully CIM will play along? Hope that makes sense! If it does, how can I change the steeing lock setting?
I'd had no problem like this before so it's a mystery. I'm a long way from any garage let alone one with Tech 2 so changing the CIM will be a recovery job! :-(
Thanks for letting me whinge about it if nothing else! Any thoughts very welcome, before I bite the bullet?
Terry
900 (air suspension)
900 Carlsson
9-3 Aero (written off)
9-5 Aero (son killed it!)
9-3 Estate (Hirsched)
