I went to jump start my nephews car today ( Vauxhall but with same 1.9 engine as mine ) and wonder if anyone has any ideas on what could be wrong with it.
This is the tale.
It had not been started for 48hrs and the battery read 6V nothing had been left on and previous to that it had been run every day with no starting problems.
The battery was new 6 months ago.
Put jump leads on and left it with my engine running for 4 or 5 minutes.
Started it, removed leads, voltage 13.4, raised rpm to 2000 voltage went up to 13.7 and stayed at that when back to tickover.
Left it running on tickover for 15 minutes and switched it off, voltage slowly dropped to 12.4.
Restarted it with meter connected, voltage dropped to 11.8 while cranking and stayed at that for a couple of seconds after the engine started and then slowly went up to 13.7 over the next 8 to 10 seconds. ( engine not taken above tickover )
I have the battery on charge and it's going to be checked tomorrow but I'm a bit worried about alternator with the time it took for the voltage to rise after the engine had started and wondering if it could be the cause of the flat battery.
Thanks for reading all comments welcome. Alan
