Saab Tech Talk (STT)
Saab Tech Talk forums
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Workshop for current Saab models
Saab 9-3 Sport Saloon / Convertible / Combi (Wagon/Estate) / Turbo X / AWD (2003 on)
Rear spring
« previous
next »
Print
Pages: [
1
Author
Topic: Rear spring (Read 2925 times)
Alan
Vector
Number of thanks: 7
Rear spring
on:
31 March 2014, 08:52:36 PM »
I need a pair of rear coil springs for my 2007 1.9 vert. I believe the Saab part number is 12786582 but they are a bit expensive even GSF want £60+ each so I've looked for something a bit cheaper.
I've found some made by KYB part number RX6360. Can anyone confirm these are a suitable replacement for my car.
Thanks Alan
Logged
Aerobic
SST paid up supporter
Overboost
Number of thanks: 345
2006 9-5 Aero estate - Hirsched.
Re: Rear spring
Reply #1 on:
01 April 2014, 12:19:44 AM »
If you check the VIN label in the door shut, the row of letters and numbers across the bottom will give the specification of the suspension as it left the factory. if you tell us the code we should be able to check the part number.
Logged
Help support
SaabTechTalk
by making a Lump Sum donation or by opening a subscription.
Alan
Vector
Number of thanks: 7
Re: Rear spring
Reply #2 on:
01 April 2014, 01:22:10 AM »
Numbers and letters are
52-5-4-1-66-68-AB-BB-CB-DB
The reason for asking about these KYB springs is because Saab seem to have a different spring part number for every engine and body type but the online KYB catalogue lists the same rear spring for saloon and convertible. ( Standard RX6360 Heavy duty RX6359 )
Information about the RX6360 springs are.
Thickness (mm) 12.25
Outer Dia (mm) 138
Length (mm) 288
The RX6359
Thickness (mm) 12.75
Outer Dia (mm) 139
Length (mm) 280
Logged
Print
Pages: [
1
« previous
next »
Rear spring
