Saab Tech Talk (STT)
Saab Tech Talk forums
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Workshop for current Saab models
Saab 9-3 Sport Saloon / Convertible / Combi (Wagon/Estate) / Turbo X / AWD (2003 on)
5 speed manual gearbox
« previous
next »
Print
Pages: [
1
Author
Topic: 5 speed manual gearbox (Read 3684 times)
Viggen
Number of thanks: 10
9-5 2.0LPT.....as was, and now 9-3ss 2.0T Aero :)
on:
09 March 2018, 09:59:51 AM »
Does the manual gearbox require regular oil changes on the 2.0T, or is the unit sealed?
It was suggested to me that it is a sealed unit that doesn't require oil changes, but I did wonder......
Logged
Turbo
Number of thanks: 27
Re: 5 speed manual gearbox
Reply #1 on:
09 March 2018, 08:01:30 PM »
Not a sealed unit,change the trans fluid the box/diff will thank you..
Logged
Viggen
Reply #2 on:
24 May 2018, 10:02:11 PM »
If I get my mechanic to do it, but buy the oil beforehand, what should I buy?
Is there a recommended Saab gearbox oil, and if so, where can I get it, and how much do I need?
Logged
SaabTechTalk Team
Wide open throttle
Number of thanks: 207
Reply #3 on:
25 May 2018, 06:51:34 AM »
Personally, I wouldn't bother with changing the gearbox oil as I can't think of ever seeing a 5 speed with a box failure or that got noisy or hard to select, anyway the part no. is 93165290 for the oil a dry gearbox holds 1.9 litres so you'd want 2 litres of that, should be available from Vauxhall dealerships.
Logged
Viggen
Reply #4 on:
07 June 2018, 11:40:44 AM »
Thanks Audax, the local VX dealer has this oil in stock.
My car has around 94,500 miles on the clock, is 12 years old, and has had 4 owners before me - so I don't mind getting the gearbox oil changed. It wasn't done as part of the service I had done 3 months back, but I'll get our mechanic to do it when he looks at the droplinks/suspension knock
Logged
David
Turbo
Number of thanks: 13
Great Western Saabs
Reply #5 on:
07 June 2018, 02:06:31 PM »
Had mine changed twice. Once to flush it through for a few miles, then a second.
It certainly improved it. HTH
Logged
Viggen
Reply #6 on:
25 June 2018, 05:30:20 PM »
Just out of interest, why did Saab bother having 2 manual boxes, 5sp and 6sp? Is one better than the other? Have I got the duffer? 😅
Logged
Aerobic
SST paid up supporter
Overboost
Number of thanks: 345
2006 9-5 Aero estate - Hirsched.
Reply #7 on:
25 June 2018, 10:36:24 PM »
Marketing. I reckon the 5 speed is better. The 6 speed has crammed in an extra gear in much the same space, so it stands to reason that some of the cogs will be thinner. The 6 speed, at least in early models suffered from very stiff changes. Probably rushed to market to give the same numbers as the Germans. Alll those gears are unnecessary on a Saab with a big flat torque curve.
You need lots of gears on peaky highly tuned engines to keep the revs in the sweet spot of max torque. The Saab peak torque is the same from 2000 rpm to 4500fpm. Three gears would probably do.
Logged
Help support
SaabTechTalk
by making a Lump Sum donation or by opening a subscription.
Test pilot
Number of thanks: 22
Sadly Saabless, but with a new mistress.
Reply #8 on:
28 June 2018, 09:25:08 PM »
Quote from: sgould on 25 June 2018, 10:36:24 PM
... Three gears would probably do.
Just like early 1960s Vauxhalls!
Logged
Viggen
No longer Saab now Nippon Express 4x4
Reply #9 on:
03 July 2018, 01:03:54 PM »
Sounds like a Sturmey Archer 3 speed would do then
Logged
Print
Pages: [
1
« previous
next »
