The ET figure of 49 shows a 49mm offset. That is the standard offset on the 9-5 and the early 9-3 3dr/5dr from 1998 to 2002.
The current 9-3 uses ET41 with a 41mm offset. The wheels sit 8mm further from the centre line of the car.
I bought some new steel wheels today. They are Saab branded for the 9-3 sport saloon and are stamped ET41. The full description is 6 1/2J x 16H2 ET41.
If you put ET49 wheels onto a 9-3SS it's likely that the tyres will rub on the inner wheel arch unless you fit very narrow tyres.
We had one make of standard 225/45 17 tyres that rubbed. If you fit ET49, then the widest tyre that should miss the body should be 205 wide and no bigger in diameter. It might still be too close to the suspension members.
Here's the details from my new wheels:
