Author Topic: 93 V6 fuel pressure release.  (Read 2304 times)
Re: 93 V6 fuel pressure release.
« Reply #30 on: 24 April 2024, 09:07:36 AM »
The level sensor feeds were the first thing I checked with the Tech2.  They arrive at the ECU separately, but Tech2 only sees the combined value. Actually it only reports the lowest of the two, which is why the gauge falls to zero when one goes open circuit.
It may be warm enough today to work on the electrics without dropping anything.  I’ll try.
« Reply #31 on: 24 April 2024, 03:51:46 PM »
One stage further. and the two issues.
The P0089 fuel pressure code and engine light gets more odd each time.  Last night, as reported, the light was off when my wife drove to her concert.  When she went to come home the light was off in the car park and on leaving the event, but came on soon afterwards.   This morning I went out for fuel and, as expected, the engine light was on because I hadn't cleared it.  Then a quarter of a mile up the road it went off of its own accord.  So who knows what is going on.
The second issue with the fuel levels is a bit further on towards a solution, but has got a bit more confusing.  I disconnected the ECU and measured the resistance to each of the two level sensors at the ECU connector.  The WIS says they should be 40 Ω on full and 250 Ω on empty.
I measured with the gauge showing about ⅓ full and the resistances were...
Level on fuel pump sensor: 158 Ω
Level on second separate sensor: 121Ω
Which seems about right.
After I filled the tank, I checked the resistance again and they were...
Level on fuel pump sensor: around 23 Ω (It was wandering about from 21 Ω to 25 Ω, not steady)
Level on second separate sensor: 42.4 Ω which is about right for a full tank.
So the fault seems to lie with the sensor attached to the pump.  It can't be a broken wire in the resistance strip on the sensor as the reading is not zero, and it can't be a corroded connector in the line because that would give a higher resistance.  But it's reading below 40 Ω, so presumably the ECU is seeing this as out of range.  It implies that the float is going higher than expected, relative to the resistance winding.  All I can think of is that the sensor has become detached and is loose and moving about a bit.  But at least it's likely to have identified the sensor that's at fault, I think
It looks like a garage job to fix it.  To get to the tank, it's:
Anti-roll bar off
Exhaust off
Propshaft off
Heat shield off
Rear diff unbolted and hung on a strap to lower it a few inches
Detach fuel filler
Remove fuel pipes
Undo main electrical connector
Unbolt tank and fiddle it out
That's too much for me these days.  I might even leave it as it is for a while.  Oh! for a hole in the floor like the 9-5.
« Reply #32 on: 24 April 2024, 06:47:52 PM »
Funny.... having seen the agricultural engineering approaches to ripping open a hole in the 9-3 floor to get access to change the pump, I was wondering "what about getting a 9-5 cover plate (perhaps with part of the 9-5 floor) and spending the money on doing what Saab should have done in the first place".
Or you could just put a 20 ohm resistor in series   ;)
« Reply #33 on: 24 April 2024, 07:17:43 PM »
Both of those thoughts have crossed my mind!! :D
« Reply #34 on: 26 April 2024, 01:32:06 PM »
Two days on and the engine light is still off.  Fingers crossed...
Forte engine cleaner has arrived.  Two days late due to Royal Mail delays.  I might as well use it! :)
« Last Edit: 26 April 2024, 01:49:57 PM by sgould »
« Reply #35 on: 26 April 2024, 06:04:09 PM »
Now you will never know what solved the problem....
« Reply #36 on: 26 April 2024, 10:28:57 PM »
I'm sure it will happen again.  The last two occasions the light stayed off for a few months.  But if I put some Forte in every 6 months or so, It might confir it's a restricted fuel line or injector.
Short of running 100% of the time with the fuel pressure recorder, there's not much else I can do.  Unfortunately I would have to keep an eye out as the scanner doesn't doesn't record.
« Reply #37 on: 27 April 2024, 12:39:39 PM »
Engine light was still off this morning, but came on again on the second journey back home.
The only small positive is that, if it is the fuel pump, if that is replaced, the level sensor will be replaced too.
« Reply #38 on: 05 May 2024, 03:02:44 PM »
A further update.  I used my "cheap" code reader and not the Tech2, and that showed two codes.  The P0089 and the same code under "Pending".  So I cleared the codes and ran the engine on tickover.  No engine light, but by continually checking the codes, the pending P0089 came up after about 1 minute.  It was repeatable.   But I ran a scan of the fuel pressure and I couldn't see any anomaly.  Maybe a longer run is needed.  I'll see if I can find a way record it.
« Reply #39 on: 06 May 2024, 05:15:42 PM »
This is going to be a difficult one, as there are two modes of failure and having simulated the diagnostic methodology in WIS will likely take you to "The fault still exists"
« Reply #40 on: 06 May 2024, 05:58:41 PM »
It may be the pump after all.  WIS says the fuel pressure is supposed to be between 250 & 500 KP.a.   I have seen readings near 200 KPa.  But that may be a restriction in the pipe.
Or WIS may be wrong.  I read the section on the fuel system under the B284 engine, and it started mentioning carburettors!! :o
« Reply #41 on: 06 May 2024, 06:34:48 PM »
Moving to SI usints is usually a recipe for confusion so I'll speak automotive  :)
The test protocol in WIS talks about using Tech II to activate different modes, with a low of 1.9 bar, then in ranges typically from 2.3-2.6 bar all the way up to 2.9-4.9 bar
Thinking about the B2x5 engines they operate at 3 bar, without adjustment for boost, so it is reasonable to expect that the later cars should be capable of a flow at least equivalent to thar derived for the 3 bar pressure, though perhaps less because there is, as you said, no fuel return.  2 litres / minute flow is also a handy test value for cars of this sort of power.
If you don't have the test gear (and why should you), then perhaps you can run a flow test, which may also illustrate a restriction in the pipe ?
As you suggest, 2 bar pressure does seem low, can you perhaps use Tech II to do an internal measure on the different operating modes ?
« Reply #42 on: 06 May 2024, 07:33:19 PM »
I plan to have a play tomorrow.  It's been raining here all day :(
As the Carlsson is her car, and she has a very active social life, I have to plan any major work by agreement!!
My other thought is that there's an obstruction at the pump, restricting flow and upsetting the level sensor.  Poor suction would be harder for the pump to overcome than a blockage on the delivery side.
« Reply #43 on: 07 May 2024, 08:48:03 PM »
This is getting frustrating.   Two days ago I got a pending code after a minutes engine running.  It did that three times in a row.   So today I went down to do a more rigorous check with a timer and a recording of the fuel pressure.
I did it four times, and would it give a code? No...
[edit]
But, maybe progress.  OH went out to her local folk singing club tonight, found nowhere to park, so she came back and got me to take her.  The light was on.  Using the freeze frame function on the Car Scanner on my phone app, It recorded the data when the code was triggered.  thus is the full code, not the pending code.
Some details...
Code P0089
Run Time since engine start: 2 min 30 seconds
Throttle position: 14%
MAF flow: 5.58g/sec
Vehicle speed: 0 mph
Engine rpm: 694 rpmF
Fuel pressure: 231 KPa
Fuel level: 66%
EVAP purge: 3%
Calculated engine load: 33%
Coolant tem 78ºC
Control module voltage: 14.63v
So with 66% fuel level recorded, it seems that low fuel level is no the cause.
It looks like the 321KPa pressure may be too low.
I'll clear the code and recored each time it happens and see if there's a pattern.
« Reply #44 on: 08 May 2024, 05:43:29 PM »
A couple more code events.  Freeze Frame says fuel pressure at the time was 261 KPa and 288 KPa.  So not that low, and higher than the first one.
I thought that if the pump was producing a low pressure, it wouldn't hurt to clean the connections on the Pump Control Module.  WIS says that it's hidden under the carpet, under the middle of the driver's seat.  So I planned on a seat out job.  In the event, WIS was wrong and the control module has been moved the the rear of the front seat, under the rail next to the sill and the connector was readily available! :)
It didn't cure the problem.
