The vacuum hose diagram I posted was incorrect - it was drawn before I removed the battery and battery box so I could see exactly where all the hoses went. I used 4mm vacuum hose as the spigots on the solenoid valves were 5mm diameter and the technical support chap at SamcoSport, whose hose I bought said I needed 4mm on a 5mm spigot. The overpriced OEM hose is 3.8mm so .2mm isn't going to make a great deal of difference. The correct vacuum hose diagram is attached which matches one I found on anaother forum. The one in WIS is very confusing and of no help at all.
