The main beam switch is intermittent. If it latches on, it won't then turn off (unless you turn the headlights off).
I see that the stalk is available as a separate part but it doesn't look like it has the switch in it. So, is it possible to just replace the switch part of the CIM, albeit with some disassembly?
