Kev if it is warped, always replace any brake or major suspension component in pairs.
I had an instance of fitting new brake discs (to a Peugeot - the car I owned before my SAAB) and they were warped on fit! They were cheapish ones. but not regarded as real cheap and nasty.
Then I had an issue with the same car pulling after fitting new pads. In the end I just could not see what was wrong or why it was pulling so, exasperated, I switched the pads from left to right and it pulled in the other direction - cheap and dodgy brake pads
Dont buy cheap if you can help it; choose Brembo or my own preference - Pagid.
Check Halfrauds - I just bought a set of Pagid discs for my Jimny far cheaper at Halfords than anywhere else, and that was without using my trade card.
Like Sgould says there could be dirt trapped OR... I've had it where corrosion under the disc has caused it to shake.
