Pull the top cover off the engine and look at injector number 3, if it has a different connector it has the modified harness. All the modified loom consists of is a connector and some cables that you have to wire in yourself, they never replaced the whole engine loom. Faulty injector wiring tends to be a problem all the time, but you can test by wiggling the connector while the engine is running, you'll soon here if it's bad or not.
