Welcome!
From the plate you have a 2008 model (built Dec 2007) Saab 9-3 2.0t Vector 4 door saloon, with 5 speed automatic gearbox. Built in Trollhattan.
The codes along the bottom are for suspension and brakes.
Article : Front Spring
PartNo : 93190609
Usage : 2007-2009, 4D, 5D, B207, A,
CODE=46Supplementary Description : Kit contains 2 springs blue/yellow With lowered sport chassis
Order Quantity : 1
Article : Rear Spring
PartNo : 12764735
Usage : 4D,
CODE=AJSupplementary Description : With lowered sport chassis
Order Quantity : 1
Article : Front Anti-roll bar
PartNo : 13204072
Usage : B207, B284, Z19DT, Z19DTH, Z19DTR, A19DTR,
CODE= 4, CL, Diam 25, 2 MM
Supplementary Description : Sport chassis
Order Quantity : 1
Rear anti-roll bar "Code 3" is not listed in my parts list for 2007 or 2008... but you will have either a 18 or 19mm bar
Article : Front Spring strut
PartNo : 93190606
Usage : 2007, 4D, 5D, B207, A, LH
CODE=63, NLS-USE 12772032, 93190092
Supplementary Description : Blue Sport chassis
Order Quantity : 1
Article : Rear Shock absorber
PartNo : 12776253
Usage : 2007-2011, 4D,
CODE= 61Supplementary Description : Blue Lowered Sport chassis
Order Quantity : 1
The remaining four codes are the brakes AA-BA-CA-DA are the codes for the small "15 inch" brakes.
Article : Brake disc
PartNo : 93171497
Usage :
CODE = AASupplementary Description : front brake
15'' Brake. Diameter 285 mm / 11.2 in. Thickness 25 mm / 0.98 in.
Order Quantity : 1
Article : Brake disc kit
PartNo : 93188377
Usage : 2006-2011, Brakes 15''
CODE BASupplementary Description : rear brake
Order Quantity : 1
Article : Brake housing
PartNo : 93185745
Usage : LH
CODE = CA15'' Brake. Diameter 285 mm / 11.2 in. Thickness 25 mm / 0.98 in.
Order Quantity : 1]
PartNo : 93172182
Usage : LH
CODE = DA15'' Brake. Diameter 278 mm / 10.9 in. Thickness 12 mm / 0.47 in
Order Quantity : 1
If you feel you need new springs, consider using Eibach Pro-kit springs. They work well with the Saab sport dumpers and make the ride more comfortable, albeit a touch lower. Cheapest source seems to be from Germany -
www.ebay.de at the moment.
