Hi All,
Hope you can help, as despite having wiring diags and trawling through the posts on this forum I can't sort this out
. I have tried to fit cruise to my 97 LPT anni manual. 2 new pedal switches wired in series and checked by ohmmeter, circuit breaks when either pedal depressed. With column switch on the cruise light comes on and there is voltage to the 2 red wires on the multipin connector to the ECU/cruise module under the bonnet.
Problem is it doesn't work when on the road and there is no voltage at the connector from the loom under the dash (to the pedal switches) with the cruise switched on. Any ideas where I should go next?? I am not a genius with electrics as I'm sure you can tell, however I'm not ready to give up yet.
Cheers Mick PS - Nice to be on this forum
