Does anyone have any tips on removing the washer pump and disconnecting the pipe from the outlet.
It's still working but the washer fluid is leaking from the body of the pump.
There seems to be something on the end of the pipe that clips to the pump. You can turn it so it's not fixed solid to the pump. All the pictures I've seen of the pump the pipe to the jets goes on a small diameter pipe fixed to the pump and mine is not like that.
Alan
