I get occasional whistles, but only heard when going slowly. Not sure if it's the turbo.
Maybe you have an air leak? When you get to Karl, ask for a second opinion. It might be a leaky by-pass valve, or similar. He won't do anything to your car if it's going to cause a problem.
Could be one of the belt pulleys which is quite a cheap fix. Take the tension off the belt with a bar in the square hole on top of the tensioner and see if any of the pulley have any play.
