Author Topic: Removing ignition key leaves radio on.  (Read 994 times)
« on: 22 September 2023, 08:21:25 PM »
From time to time, and more frequently recently, the radio, etc. stay on when the key is removed.  I've tracked it down to one of the two plastic latches not moving towards the hole when the key is removed.  Is this an electronic fault, or is it just an issue that can be fixed with a bit of silicone spray?
The latch is definitely temperamental, as on occasion, it sticks and the key can't be removed. Starting the car and turning off again, usually sorts this.
Re: Removing ignition key leaves radio on.
« Reply #1 on: 22 September 2023, 08:30:19 PM »
@sgould It's the pop up button that's at the base of the ism,that gets pushed down when the fob is inserted..If it stays down,the SCL won't engage,radio won't turn off(if on) and doors won't lock..System will think there is a fob in the ISM still..
« Reply #2 on: 22 September 2023, 10:16:14 PM »
Thanks, I'll have another look. Although when I have felt down there, it seems to be all one piece and the only bits that seem to move are the two side latches. but if the up/down movement is operating the latches, then I may have to investigate further as it's only one latch that sticks.
« Reply #3 on: 23 September 2023, 04:32:07 PM »
Never worked on a 9-3, but I suspect it's a mechanical issue, similar to the issue that can affect the 9-5
« Reply #4 on: 26 September 2023, 12:36:22 AM »
9-3 ISM is electronic..
