It should do. Some markets require a full size spare. And the Carlsson was supplied with one. It's only a 17 inch with a 225/45 17 tyre, but it fits over the standard 17 inch brakes at the front. I tried a 235 18 tyre with the 18 inch wheel and it was just too high for the floor to sit flat. The 17 inch tyra actually supports the boot florr, so it's a tight fit. The body at the bottom of the well for the wheel is domed, so the wheel will only sit with the outside of the wheel upwards. You can't turn it up the other way and store stuff inside the wheel.
