Back to this again - car is due a service, but a couple of months back I did try swapping coil packs with some other ones I had got from a breakers. I thought that by changing one or two, the idle had smoothed out a bit (tend to get some idle vibration in the car, and also still have the fluctuating idle issue which may be related to the a/c compressor, which is working but getting noisy).
However, the other day, manoeuvring the car into the garage and getting out to check how far away I was from the stuff behind, I heard the sort of popping noise coming and going again. The engine speed fluctuates a bit, and as it is doing so, there is a pop noise coming back through the air intake and into the air filter box. Not very loud, but noticeable.
I've had the car almost 5 years now, and no one has ever diagnosed what this is, and it doesn't seem to adversely affect the every day running of the car, or show up on Tech2. So I'm still baffled!!!!!!
Any ideas?
