High Speed suspension shake & steering woes are a common issue with after market wheels on SAAB's. Anyone know where you can buy spacers that convert the 65.1mm diameter SAAB hub to 72.6mm. Turned some up myself and they solve all the problems buy I can't make them thin enough (my DIY's are 20mm) and need 10-12mm.
Buying a better lathe does seem a rather expensive option
For some reason the standard manufacturer supplied polycarbonate rings just don't seem to work on SAAB's. 93 & 95 suffer the same. Anyone know why?
