This is the non-return valve on the crankcase breather pipe. The pipe runs from the oil trap behind the engine to the throttle body. This valve often snaps. It comes with the rigid pipe to the engine attached. But you can fit a metal valve and fit it in the pipe.
Hi , I get this now BUT - why was/is there a nipple from the cam cover then with a small vacuum pipe with another small check valve on it just hanging to atmosphere on mine = this where i think the last owner / mechanic messed up!
One extra NOTE: When i initially investigate and noticed that 'extra nipple' from cam cover to thin vacuum to one way valve to atmosphere , which was just hanging spraying oil everywhere - i rectified that by simply replacing the cam cover nipple with one for the system Without the extra nipple - THIS CAUSED UNTOLD PROBLEMS - OIL WAS COMING OUT IN MORE PLACES!
So hence why I am on this road - i am really stumped now 0 If you guys are saying ' oh the system should be plumbed like this ' but when i did that initially made it worse -
