So, emergency call out to rescue the black Aero on Sunday evening, which wouldn't start after filling up (engine barely trying to turn over). Jump start & off she goes. 14.2v at the battery when running,
Put the battery on charge, saw it go up from 12.8v to 13.3v, full bars on the little charger so disconnected & left to stabilise. 2 hours later shows 12.8v, so seems OK
Next morning she started, but only just, never mind, 230 miles to charge her up. 230 miles later, turned off, left 5 minutes & it wouldn't turn over. Bump start & visit to motor factor for a new battery. All is good
Tested the battery tonight. Still showing 12.8v. I expected 12.0, or even less
It seems the battery can retain a voltage but is unable to deliver current
Any ideas what's going on, I haven't seen this failure mode before
By the way, OpenSid tells me the car start time is now 0.9 seconds, when it was 1.4-1.5 seconds before. I did suspect the battery was getting weak.
