whats up man, im new here just wanted to get an update on your cim issue,see if you solved it and any information you may have?
. After months of trblshooting and trying this and that i finally got a msg diff from the rest,and said "enabled security access type 3" FIRST time ever seeing any progress in my quest for security access. So does it mean i really have access to work? I was trying to get to the journey of wanting to change my cim after i buy one, but i also wanted to try the function "Force key to turn"** now that i have security access. So any info you may have would be a Godsend.
Update:
so after several attempts trying to gain security access, i eventually once again as able to get Security Access type 3. However, after that nothing reallly happened, the tech 2 stayed on the last screen it was on and couldnt exit to do anything or task. Moreover,i was told i needed type 1 access to add my cim anyway.
Thereafter, i decided to clear all DTCs and rescan,to which came back no dtc stored. I did it twice and got none back. Car more or less still in the same state,where everything seems to work in car as should except its still CRANKING but not STARTING.I did some basic testing/troublshooting of:
fuel pump,(think im hearing it as well)
fuel pump relay, tested that,hear it clicking(just rememebered should test relay terminals in fuse box today)
did the same basic testing of CPS(learnt one trick where if the tach is moving to normal cranking rpm when trying to start then the CPS is fine,allegedly)
fresh gas in the car.
Jumped starter relay terminals and still no start,just cranking.
What ya think,let me have it,dont be shy.
