Author Topic: Flat spotted tyres.  (Read 193 times)
Flat spotted tyres.
« on: 16 April 2024, 09:37:11 AM »
If you have a car parked in the garage for a few months, is there a good way to fix flat spots on the tyres?
My son's car got stuck in the garage once our building work started and a skip was dropped outside the garage door.
The car is SORNed, but the skips have been there far longer than we anticipated. The tyres are all good/reasonably new, and we have tried to move the car about whilst it has been in there so it wasn't sitting on the same patch continuously.
Re: Flat spotted tyres.
« Reply #1 on: 16 April 2024, 12:16:44 PM »
The tyres should recover if they are not abused when first driven.  Alternatively you could pump them up to a much higher pressure to reduce the size of the contact patch, as long as you reduce it before getting it back on the road.
It depends a bit on the age of the tyres.  There’s a date stamp on the side. Four digits. First two are the week. Followed by two for the year.  10 years is considered the life of the tyre in normal circumstances.
« Reply #2 on: 16 April 2024, 02:50:20 PM »
As Will says, pump them up to the max and they should be fine; and you say, rolling the wheels even a few inches and changing the contact patch will help. If you're really worried then of course you can always jack each corner up and rotate the wheel, and/or then lower it onto some foam matting.
« Reply #3 on: 16 April 2024, 05:19:21 PM »
Pump the tyres up above normal pressure and they should be OK
Let them deflate & be flat against the floor and there will likely be a permanent vibration in the future
