Hi
I've had two occasions where the engine simply wont start, turns over fine but no ignition.
Both occasions the car had started fine from cold, popped into a shop of similar, came out 20 to 30 mins later and it wouldn't go.
First time my Mrs was driving and I thought it might just be the immobiliser not kicking in as her key has been asking for a new battery for nearly two years now (one of those things that keeps slipping my mind
). Tried my key and still no go, locked and unlocked the car, tried a few more times and it started just fine.
Second time was today we were in the dreaded Ikea for a good 45mins, came out and it wouldn't start. Gave it a few tries and eventually it fired up.. This time it was my key which has a new battery in it..
From what I've read it sounds like classic early signs of the CPS going. I've read a few post about measuring the resistance across pins 1 and 2 but some state you need to wave a magnet in front of it to test properly and others don't. Also read this still isn't a fool proof test for the sensor.
Would somebody be able to kindly clarify what a valid test is, if there is one?
Cheers
D
