Author Topic: Possible gearbox problem - no drive  (Read 10114 times)
« on: 18 June 2018, 09:07:12 AM »
Got a call that my dads 9000 Aero has lost all drive, sudden failure in a car park, so I had a look at it yesterday
Symptoms, no drive in any gear, no adverse noises or crunches
Tests carried out,
Slave cylinder is actuating on clutch diaphragm OK,
Gear linkage is positively engaging in gearbox, gear lever feels normal
Car in the air, rotate road wheels. Each roadwheel rotates and can be heard to be rotating the diff. However, the opposite roadwheel is not rotating in the opposite direction
Engine running, change gears without using clutch, no crunching noises
Inspection plate removed, no signs of masses of friction material at the bottom of the bell housing
Any suggestions for what this might be, it's as if the input shaft has been broken, can clutch splines just get ripped out ?
« Last Edit: 18 June 2018, 09:09:24 AM by carrera »
Re: Possible gearbox problem - no drive
« Reply #1 on: 18 June 2018, 10:53:16 AM »
If you can change gear without using the clutch when the engine is running, it implies that there is no movement of the cogs in the box, so nothing connecting the engine and the gearbox.
If there are no noises, it would seem that the two halves of the clutch are still intact.
The symptoms are that the failure is as if the clutch pedal is stuck down.  Is the clutch released permanently?  The movement you see on the slave cylinder may be misleading. It may just be moving from “clutch released” to “clutch further released”.  What you need to check is whether the slave is allowing the diaphragm to return and grip the clutch when the pedal is released.  Maybe something simple like the rubber hose has failed internally and is acting as a non-return valve, keeping the clutch permantly released.
Otherwise, I reckon you will need to get things apart and have a look,
« Reply #2 on: 26 September 2018, 11:01:57 PM »
Thanks for the reply - just a belated update from me as I had to diagnose an ABS issue for him yesterday.
He took it to a local Saab breaker / specialist. Apparently one of the main shafts in the gearbox was broken so it was gearbox out, strip and replace with s/h component. I never got a completely straight story.
Just been doing some reading in the 9-5 forum, flabbergasted that this thread was the most recent in the 9000 forum. Are there so few 9000 owners out there (and in here) these days ?
« Reply #3 on: 27 September 2018, 12:18:47 AM »
There seems to be very few 9000 cars around.  I think that there was only one at last months national meeting - at least on the first of the two days.  I think a couple more came on the Sunday.
« Last Edit: 27 September 2018, 10:52:29 AM by sgould »
« Reply #4 on: 27 September 2018, 08:25:36 AM »
Thanks, not that many on the roads that I see either, best try and keep his going. I had it from new (well ex-demonstrator).
Getting a bit more off topic. I'm not getting notification about replies to topics. There's a valid email address in my profile and I am subscribed to the topic. Is there something else I need to look at, or is it a GDPR hangover ?
« Reply #5 on: 27 September 2018, 10:54:24 AM »
I’ll check the Notify/Subscribe function when I get back home later.  I can’t see anything wrong at the moment, but doing admin stuff on a iPhone is a recipe for disaster!
« Reply #6 on: 27 September 2018, 10:50:12 PM »
I've had a look through the settings and I can't find anything that would cause this.  All the forums have the standard default setting.
« Reply #7 on: 27 September 2018, 10:51:54 PM »
I've set myself to receive notifications in this topic.  We will see what happens.
« Reply #8 on: 27 September 2018, 11:38:18 PM »
Thanks, so here's a reply to see if either of us gets a notification  :)
« Reply #9 on: 28 September 2018, 01:40:55 PM »
I got nothing. I’ll have another look when I get home on Sunday.
« Reply #10 on: 30 September 2018, 03:37:50 PM »
Another try...
« Reply #11 on: 30 September 2018, 07:52:50 PM »
Nothing coming in to me for either of your replies either. Guess it's a thread or sub forum issue. Let me know if you would like me to do anything to help track it down. I could respond on the 9-5 rear light thread ?
« Reply #12 on: 30 September 2018, 08:14:22 PM »
The settings were at default, I tried re-enabling the notification, but it doesn't seem to have worked.  I'll nave another look later.  There's a forum discussion board somewhere.  I'll look at that too...
« Reply #13 on: 31 August 2019, 01:29:44 PM »
Thread resurrection.
I got a call from my Dad yesterday, saying clutch has gone, so I loaded up the trailer and collected his car from him.
It is showing exactly the same symptoms as before
Rotate one roadwheel, the other does not rotate in the other direction. Well, to be more precise you see an initial reversal on the CV as play is taken up and then nothing more.
If I rotate a roadwheel in a forward direction the drivetrain sounds fine. If I mover the roadwheel in a reverse direction there is a light click click click. I have had my stethoscope out and that noise is coming from the gearbox, not the diff.
So, my conclusion is whatever failed before has failed again.
Any suggestions as to what that might be or other diagnostic tests for me to perform ?
« Reply #14 on: 10 September 2019, 10:50:32 PM »
The conclusion seems to be that it's an internal gearbox fault, as i don't have any other ideas.
It's up in the air at the moment whether my dad will let the garage do it, or leave it for me to do
I have rebuilt a couple of gearboxes befor, but that was in a workshop with the right presses etc - and I haven't researched how easy or difficult these are to do, or the parts availabilty.
For now I'm just going to put a wanted ad up, just in case someone has one lying around
