Following a long time of harsh thumping through the floor when you suddenly put your foot down or lifted off, and after consulting the oracles on the Nissan Qashqai Facebook group, I decided to buy myself a bottom gearbox mount, as that was a likely suspect.
The part was only about £17, was a bit bigger than expected, but features two bushes. It arrived on Thursday, and as we weren't doing much this weekend, I decided to fit this myself!!
Well, it's 3 bolts, two that hold one end in a bracket onto the gearbox, and one that holds the other end into the rear of the subframe.
With the front end of the Qashqai up on ramps, I crawled underneath and began to slacken the bolts on the gearbox end. Those loosened quite easily, but the one into the subframe was rock solid. Although after much effing and jeffing, I managed to get it out.
I managed to pull the old mount out, and as you can see from the photo, the larger bush in the subframe end was truly knackered and torn. Hey presto, I made the right call, and the job was relatively straight forward.
While I was at it, I also replaced a broken bit of exterior trim in the corner of the screen on the driver's side, which had been missing for a while.
All in all, well pleased with myself.
I was going to get the back wheels off the 107, to clean up and paint the drums.....but I decided to rest on.my laurels.....that's a job for tomorrow!! Maybe!!!
