Saab Tech Talk (STT)
Saab Tech Talk forums
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Workshop for classic Saab models
Classic Saab 9-5 (MY 1998-2010)
ABS warning light
« previous
next »
Print
Pages: [
1
Author
Topic: ABS warning light (Read 974 times)
SST paid up supporter
High Output Turbo
Number of thanks: 17
MY04 9-5 Aero auto estate
ABS warning light
on:
09 June 2023, 08:45:59 PM »
... is on. Car felt completely normal otherwise. I've done a bit of Googling and among the possible causes seem to be a duff wheel sensor, low brake fluid, or the failure of the unit. I'll check the brake fluid level tomorrow morning but if that's ok am I right to assume that it's ok to use the car with a requisite degree of care?
Logged
High Output Turbo
Re: ABS warning light
Reply #1 on:
09 June 2023, 08:52:06 PM »
In fact damn, I realise the brake light is on as well.
Logged
SaabTechTalk-Team
Test pilot
Reply #2 on:
09 June 2023, 11:48:12 PM »
That looks more than a broken reluctor ring
I would check brake fluid level first,fuses, & then take an exploratory drive, somewhere quiet, to see what happens with gentle, normal & hard braking
Having Tech II would make diagnosis too easy
Logged
High Output Turbo
Reply #3 on:
10 June 2023, 01:04:15 PM »
Thanks Carrera. Checked the fluid level this morning and it was bang on the Upper line. I did actually get an involuntary chance to test hard braking not long after the light came on yesterday when a lorry pulled out on me and it felt completely normal. I also read somewhere that if the ABS unit itself has failed the speedo fails, which it didn't. So I'm thinking / admittedly hoping that it's a sensor / ABS ring.
Logged
steventon95
LPT
Number of thanks: 7
9-5 Aero Estate and a 9-5 Saloon (both ancient)
Reply #4 on:
11 June 2023, 01:34:13 PM »
I had a reluctor ring (NS front) crack following a visit to an interesting pothole a few weeks ago. Tech II will always tell you has gone wrong.
Logged
High Output Turbo
Reply #5 on:
11 June 2023, 09:56:57 PM »
Cheers - yes. The lights went off within minutes of starting the car this morning, stayed off for about 150 miles, then came on again at a fairly random moment. Tech II indeed beckons.
Logged
Print
Pages: [
1
« previous
next »
ABS warning light
