I've normally run my 150 Tid on supermarket diesel and never believed it was inferior to branded diesel but....
The misfire initially was only for 10 seconds or so on cold starts, I checked the glowplugs and found 2 were not working.
4 new glowplugs and no misfire, but it came back. This time slight but noticeable through most of the rev range.
No 3 injector wiring changed and no misfire, but it came back. Only on cold starts so checked the glowplugs, all OK but swapped them in pairs with the old ones anyway just to check but it didn't help.
I suspected a temp sensor but as MPG didn't seem to be affected decided to see how it was when the weather got warmer.
It slowly got worse, to the point where it misfired all the time but only below 1500 rpm.
Full throttle below 1500 rpm and no misfire light throttle it misfires made me think blocked injector.
In the last 6 weeks I've done four 200 mile trips and two 100 mile trips towing a 1300kg caravan and two 200 mile trips solo mostly on motorways.
All these miles were done using branded diesel ( mainly Shell ) and since then I've done around 300 miles of mixed running also using branded fuel.
For the last 400 miles it's been running great with no sign of a misfire.
Is it because the 1000 miles towing at 25 mpg cleared the injectors is it because I've not used supermarket diesel or is it something else
Alan
