Today I was a bit shocked!
I decided to try and sort out the P0059 fault which indicated a fuel pressure fault. After looking at things, I decided that changing the fuel pressure sensor was the best option. Opie Oil were selling a Bosch one for £27. Orio were doing the same part for £201.
Talk about making Saabs expensive to repair!!
Anyway, £27 was cheaper than a trip to a specialist, so worth a try. I read the WIS instructions which stated that the fuel pressure should be reduced to zero by carefully pressing the relief valve until no more fuel came out. I did this. I even used a plastic tool to avoid any spark risk. Then it was just a case of one connector and two small bolts. Everything went fine until I eased the old sensor out...
... it came out followed by a fountain of fuel still under pressure!!!
I was covered in petrol.
Job was completed. Car started and engine light was out, without the need for a Tech2 session. So, hopefully that was the issue.
I've had a good wash and changed my clothes, but the smell of petrol still lingers...
