well, that is a good point.........
Thing is, all my assumptions are only based on what I have read on the www on what others have done with the same problem. I have yet to replace anything yet! It seems a straight swap to another /same, MIU, married to the car does the trick. In the UK about £40 can get you a MIU and then you have to marry to the carry......it's a bit more of an investment here......
TBH...I strangely quite like the quirkiness of it and if you reset the fuse 4 after you have driven, all is well. However, if you go for 5 or six drive cycles my needle is beyond vertical. Also, if you dare press the night panel this really messes things up and accelerates the process somewhat......so agree with you, it probably is more to do with the circuitry...but it seems most have solved it by replacing the MIU...I have yet to read of anyone who has solved it by replacing one stepper motor.....which is what I wanted to do.
I'll see how I get on....as I'm driving it much more now and really enjoying my new flying machine......
M
