Since doing the oil change last week, I'm getting different readings every day I check.
It was fine when I put the oil in, following morning it read around 15mm over the max mark, although, my drive is slightly sloping down and to the right.
I parked it on the main road for an hour and it read on the max mark, I've just checked it on the works carpark and it's about 2mm above the max mark.
Could I have an airlock in the oil causing spurious readings ?
I'm taking it to work again on the morning dead early to find the flattest/levelist space to park and will check it after 5 hours when I get my break. If its still just above the max mark do I need to drain some or will that amount be ok?
