The other oddities with that SID display is that you can only alter the language/metric/imperial settings by turning on the ignition, but not starting the car. And when clearing the "Time for service" message, you hold the CLR button on the steering wheel for several seconds, as before, but after getting the "Cleared" message, the normal display comes back while you are waiting, making it look as if it's failed. But keep holding and"Serviced" appears!!
