Welcome!
Do you know which audio system you have? There were three...
4 speaker system fed from the head unit (EHU) hidden behind the aircon panel - the CD player hangs from it. The Fascia Control panel (ICM) is just knobs and buttons.
7 speaker system. Speakers as above, plus a centre dash speaker and two bass speakers in the front doors. These speakers are driven from an amp under the passenger seat. The fascia control panel has a keypad and a 3 inch square green screen.
13 speaker system. As seven speaker system, but with two 6 x 9 inch speakers in the rear driven from another amp in the boot. And four small tweeters in parallel with the original 4 speakers.
All the units and amps are linked by optic fibre. The two cables form and optic ring main. It must be complete for any of it to work. The usual culprit is the amp under the passenger seat. It rusts and fails. This is caused by water ingress through the fresh air inlet and heater blower. The water in the area in front of the windscreen builds up if the drain is blocked. Clearing the drain should be part of every service. It is often forgotten.
