Author Topic: saab 93 (2008) tid.  (Read 2005 times)
tech07
saab 93 (2008) tid.
« on: 13 April 2020, 09:32:09 PM »
hi,
i,m  new to the sight,
i have a fault code on my car p0650-04
malfunction indicator (mi) control circuit open.
would any kind person have a wiring diagram for the mil light
to the ecu or pin numbers many thanks.
Re: saab 93 (2008) tid.
« Reply #1 on: 13 April 2020, 11:05:20 PM »
Welcome !
What's the issue with the car, is the check engine light not coming on when you switch the ignition on ?
« Reply #2 on: 13 April 2020, 11:37:20 PM »
Welcome! :)
The code P0650-04 is for the check engine light not lighting up when the ignition is turned on.
The circuit for the lamp has a 12v supply to the instrument panel at pin 3.  Then it is earthed through pin1.  The earthing is done by the ECU (pin 49).  The wire (brown/white) goes via pin 30 on the 102 pin connector under the left hand windscreen pillar, and pin 17 on the 24 pin connector in front of the battery and a black/white wire to the ECU.
On the diesel the pins on the ECU are very vulnerable to corrosion.  The ECU is in the front wheel arch under the right hand headlamp.  There's a lot of water spraying around that area, especially if any of the panels are loose or cracked.
tech07
« Reply #3 on: 14 April 2020, 04:56:36 PM »
thanks very much for your info.
i myself did my apprenticeship with a saab main dealer,
twenty five years experience up until 2002.
i have at the moment doing a classic 900t 16v
one of the very first 16v turbos to be imported
 to stalinbourgah import centre grimsby.
regards gerald.
