Workshop for current Saab models => Saab 9-3 Sport Saloon / Convertible / Combi (Wagon/Estate) / Turbo X / AWD (2003 on) => Topic started by: Steve McF on 24 July 2020, 08:41:32 PM
Title: Headlamp washer jets not working?
Post by: Steve McF on 24 July 2020, 08:41:32 PM
Now I've had the Aero 2.5 years now, and I've never noticed or checked the headlamp washers. Today, I got the Missus to look at the front of the car whilst I  put the windscreen washers on and, yep, you guessed it, the headlamp washers don't seem to be doing anything.
I assume these should be working at the same time as the screen washers?
What should I be looking out for to try and get these working again?
Title: Re: Headlamp washer jets not working?
Post by: sgould on 24 July 2020, 09:37:55 PM
Headlamp washers will only work under certain conditions.
1.  The headlamps have to be turned on.
2.  You have to hold the screenwash switch on for at least half a second, maybe a bit longer, but a quick squirt of the screen won't activate them.  Then they should spray twice.
3.  Once they have worked, they don't work again for the next half dozen screen washes, unless 2 minutes have passed.  Those numbers are about right.  But they can be altered by Tech 2.
Post by: Steve McF on 24 July 2020, 09:46:30 PM
Thanks Will - will have to try it again now that it is dark .....
Post by: Steve McF on 31 July 2020, 06:11:02 PM
Well I've tried it - lights on and pulled the stalk back for around 3 seconds. Got out and had a look, but no wet on the lamps at all :(
Post by: sgould on 31 July 2020, 06:51:33 PM
There's a separate pump for the headlamp washers.  If it was tried when it was frozen, it may have burnt out.  Or the motor may have turned and the impeller frozen which could have snapped that off. Or just blown a fuse.
I don't think that there's a non-return valve in the headlamp system. Can you head the pump running? It plugs into the reservoir behind the LH headlamp, so be careful if it starts working when you're listening, you will get wet!!
Post by: Audax on 31 July 2020, 11:47:40 PM
The pumps failing is really common unfortunately, I had to do one on the aero a few years ago and the replacement was 80! They used to only be 20 back in the day.
Post by: Audax on 01 August 2020, 06:07:23 AM
Seems you can get a brand new one for just 35 these days!
Post by: Steve McF on 01 August 2020, 01:19:08 PM
Worth checking the fuse first I guess. Which fuse is it I need to look for?
Post by: sgould on 01 August 2020, 07:40:26 PM
Fuse & Relay
