This standby car (2.5 GM900 Coupe) tends to get very misty within, and I suspect a very slight leakage somewhere in the cooling / heating plumbing. The water loss is very slight and only needs a top up after a couple of hundred miles. Nothing at all obvious on opening the bonnet, even after a longish run. Any suggestions as to the most likely place to look for a leak?
