Author Topic: The old 'Jumping Gear Nob' has returned!  (Read 5898 times)
nigsy
« on: 28 April 2014, 04:13:57 PM »
Yep; Summer is on the way and the perennial problem of stopping the top of the gearstick from springing around the cabin has returned.
Has anyone found a permanent solution to this issue? last year I packed it with tin foil but it was only a temporary solution.
(SAAB 9-3 Aero 05 plate, Manual)
johnr
Re: The old 'Jumping Gear Nob' has returned!
« Reply #1 on: 28 April 2014, 05:42:04 PM »
You could just leave the spring out - seems to work fine without one.
ReAxs7
  • Skoda Octavia Mk 4 SE L First Edition
« Reply #2 on: 10 May 2014, 03:13:48 PM »
A bit like the foil method but I cut to size a strip of the reflective insert taken from the packaging for a pair of Osram H7 Night Breaker bulbs. [I'd heard of the foil trick but as we were out for a drive at the time of need I utilized what was to hand in the boot.]
I did think I might eventually have to resort to Loctite 243, a medium strength threadlocker, but the gear knob stayed put for the remainder of our ownership which must have been a further two years. I can only suggest this may have been down to the reflective insert being thicker than foil.
« Last Edit: 31 May 2014, 05:17:54 AM by ReAxs7 »
« Reply #3 on: 11 May 2014, 12:32:19 AM »
I used PTFE tape and it worked
