Changing handbrake cable
Started by paddysaab, 07 April 2012, 01:18:04 AM
paddysaab
Hi Guys
Quick question. Do I really have to take out seats and carpet to change a handbrake cable or is there some secret method known only to the gurus on this forum. It just seems like a huge amount of stripping out to get to one little plastic clip.
Thanks
Paul @ Kippen
paddysaab,
You can fiddle things through without taking the seats out.  Though I've done this job a few times I can't remember all the details.  To me that means it was fairly obvious and straightforward.  One thing I do remember is to attach a piece of stout wire to the end of the old cable at the handbrake end.  Use the old cable to pull it through then use the wire to pull the new one in.  This gets around all the monkeying about trying to get the cable above the tank.  I've known people drop the tank to get it back in.
Paul @ Kippen.
make sure its attached well - Ive had stuff come apart in similar situations and open a whole can of worms
paddysaab
Right so, it looks like I should be able to fiddle things through by taking out the centre console and feeling for the little clip. Might have to loosen the seat to make a little room under the carpet and slacken the tank mount slightly. If it goes wrong, I'll just have to do it the hard way ;D
Thanks for the confidence boost
Thorfinn
...but in my experience, it's no big deal removing the seats, although the Torx bolts at the front can be a bit fiddly. And be careful with the electrical connectors (at least 2 per seat). But once the seats are out - and you've got a nice new scratch on the paintwork caused by the sharp corners of the seat rails as you hoist them out of the car ::) - then you've got so much more room to work with.
racingsnake
I cheated last time and cut a little flap in the carpet, once I had finished it all went back together and you can't see where I cut it.
