Author Topic: 1997 900s convertable, roof problem  (Read 13794 times)
ianswing
« on: 25 June 2012, 07:08:26 PM »
as above,ive a 1997 900s and had to try sort the latching motor as window wouldnt lock down and we had a 1300 mile trip from spain to do, got a temp repair to a bush to enable it to lock but now it wont unlock  >:( ive located another motor but how do you get to the installed motor while the hoods locked down ? also got chance of a nearly new 9-3 motor (1998) which the guy assured me will fit as it was a factory udgrade/recall , any views gratefully accepted.  Ian..w/york's
Re: 1997 900s convertable, roof problem
« Reply #1 on: 25 June 2012, 11:12:39 PM »
Welcome! :)
saab talladega turbo
  • Number of thanks: 12
« Reply #2 on: 30 June 2012, 11:22:28 AM »
It's strange they say it will fit as 900's use electric motors and 9-3's use hydraulic rams ans pump.
ianswing
« Reply #3 on: 30 June 2012, 12:28:57 PM »
I was under that impression as well, but seemingly the latch motor on the cover is the same just a slightly different  lock mechanism on the ends of the alloy beam,with motor off it matches my photo's of the old one,colour coded wires are the same but the cable is slightly different so i got the section of loom as well, will post up when i go back to spain and try fit it,was hoping there would be a better way of opening the locked cover,dont fancy laying in the boot but if thats the only way arghhhhhhhh !! :o
« Reply #4 on: 30 June 2012, 03:47:31 PM »
Oh I thought u ment roof motor! Yeah possibly the same then.
You do know you can release the tonnue cover in the boot with the wheel brace?
ianswing
« Reply #5 on: 30 June 2012, 05:48:11 PM »
oops, I didnt know about that  :o ive not seen it in the handbook :-/ where is it ? that'll save me a right job doh.  Ian
« Reply #6 on: 30 June 2012, 09:26:34 PM »
Sounds like you found the right person to help you sort it out Ian. Be sure to let us know how you get on  ;)
« Reply #7 on: 30 June 2012, 10:23:06 PM »
Right. If you open the boot and look to the right and up and there's a gap in the carpet. If you've got the car manual it's in there too. You put the wheel wrench in a slot and release the tonnue.
« Reply #8 on: 30 June 2012, 10:29:34 PM »
Try this.
ianswing
« Reply #9 on: 30 June 2012, 10:39:35 PM »
superb,thanks for the help, saved me a bad back lol...Ian.
« Reply #10 on: 03 July 2012, 10:38:38 PM »
Any luck with your roof.
ianswing
« Reply #11 on: 03 July 2012, 10:47:21 PM »
Not going back to spain till mid august,will post back the result.
