Author Topic: Dame Edna Xenon Ballast(control unit)  (Read 16364 times)
Mr Linear
« on: 20 January 2013, 05:04:34 PM »
I have a feeling my flickering xenons may be down to the ballast/control unit.
Do all HID equipped 9-5's use the same units Valeo LAD5G with 12 pins?
The flickering is getting worse.  :(
Thanks.
Mr L.
Re: Dame Edna Xenon Ballast(control unit)
« Reply #1 on: 20 January 2013, 06:19:51 PM »
Article : Electronic unit
PartNo : 5408497
Order Quantity : 1
Same part in 2006 and 2010.  Same both sides.
[EDIT]  Just gone back further and the ballast unit is the same for the 2002 car too.
And over £200 new :o
« Last Edit: 20 January 2013, 06:23:33 PM by sgould »
Mr Linear
« Reply #2 on: 20 January 2013, 06:41:37 PM »
Thanks sgould.
My suspicions lead me to the control units....don't want to buy new bulbs as well.
It's a tricky one to diagnose without buying expensive parts on a trial an error basis!
I have also read that the control units need to be programmed if replaced.
Is that correct?
May just wait till they die :)
« Reply #3 on: 20 January 2013, 07:33:23 PM »
No they just get unscrewed and a new one screwed in.
Just watch the 23,000 volts.........  :o
« Reply #4 on: 20 January 2013, 08:02:35 PM »
Just double checked this, and I think that you only need the Tech2 calibration for the headlamp levelling, if you change the levelling module or the sensors.
Mr Linear
« Reply #5 on: 20 January 2013, 08:27:20 PM »
I can just imagine leaving two smoking footprints in the snow!!   ;D
Saabman
  • Number of thanks: 20
  • 9-3 Aero
« Reply #6 on: 20 January 2013, 10:46:27 PM »
I'd very much doubt it would be both ballast packs have failed they are pretty much bullet proof, is it both lamps flickering?? if not swop ballasts from side to side to see if it transfers the problem? If both sides I'd be thinking more along the lines of a wiring fault or earth fault
GeoffW
  • Sadly now Saabless, what next?
« Reply #7 on: 22 January 2013, 08:13:24 PM »
I seem to remember someone having both Xenons flickering fault recently and that was caused by an earth fault somewhere that seemed totally unconnected with the headlights (like the rear light cluster).
I had a recent problem with one xenon failing (see my post from pre-Christmas) was confirmed as the control unit by swapping the headlight units over temporarily to eliminate possible fuse holder solder fault under the main fuse box behind the battery.
Mr Linear
« Reply #8 on: 22 January 2013, 08:58:26 PM »
When the weather gets better i'll swap the units over an see what happens.
Incidentally I noticed a few flickers when I drove over some bumpy stuff.....iirc did somone on the forum solve flickering lights by replacing a load sensor???
Mr Linear
« Reply #9 on: 13 March 2013, 12:45:57 PM »
Managed to swap the control units over and it appears that it is the drivers side that was causing the problem.
OEM from Saab are £205 + vat.
I may go down the used route.  :'(
Mr L.
Mr Linear
« Reply #10 on: 14 March 2013, 08:46:43 PM »
Getting confused now  :(
Yesterday when I swapped the ballasts the left hand light flashed a few times, so I thought problem solved.
This evening checked again, this time the right hand light (the one that was causing problems) flashing and flickering again.
Will have to swap the bulbs now to double check.
Mr L.
