The 2003 9-5 has been having a little bit of a rest, and has been suffering from non starts from a low battery.
The passenger window was dropping so time to dig one of my green runners off the shelf & fit that to allow a return to normal window operation. As usual, the rubber seal from the rear of the door was displaced & in the bottom. I cleaned up the runner, sprayed with silicone & reassembled
As part of testing I noticed that sometimes the radio was staying on. Oh, so here goes with another of the usual repairs.
I found my special home made tool that allows the removal of the ignition barrel. Literally 2 minutes & she was out. There followed a couple of hours of cleaning the barrel, filing some of the pins to make the rotation operation smoother & manually operating the return mechanism so that it sprang back correctly.
I'm hoping this solves the non starts, a battery test said that the battery was weak, but still OK to use, the voltage drop wasn't too bad at all.
I suppose we'll find out soon enough if it is the battery or not
