Author Topic: Coming soon to a Saab 9-5 near you....  (Read 28221 times)
philg
  • Number of thanks: 6
Re: Coming soon to a Saab 9-5 near you....
« Reply #30 on: 19 March 2013, 11:10:43 PM »
It all seems to work! :)
Just need to get the auto dimming working.  Maybe I've used the wrong source of power.  It sort of worked to start with, something set wrongly, probably...
On my previous install I took a feed from a pin in the headlight switch for the dimming. Is this where you are pulling it from?
« Reply #31 on: 20 March 2013, 12:33:20 AM »
I'm not sure!!  it was one I used for the DAB unit, but that didn't dim.  I remember trying the light from the lighter socket below but that didn't work for some reason.
I'm off on a long drive tomorrow, so I will have a more leisurely look when I'm back home next week.
« Reply #32 on: 24 March 2013, 10:47:48 AM »
I seem to have found how the dimming works, sort of...  There's a menu option, but it doesn't dim enough.
And two disappointments.
The original radio would stay on as long as the key was in the hole.  That must have been controlled by the DICE through the I-Bus.  I've used all the original leads and the Kenwood will only work with the key fully on in the ignition position.  Something to fix.
And the car relied on the display to show the clock.  The Kenwood has a clock, but it's only displayed in radio mode.  When the satnav is on, there's no clock on the dashboard.
But it works, and took me around the country in the last four days. Just a few quirks to find a way around.
« Reply #33 on: 24 March 2013, 06:16:33 PM »
Here's the install with the DAB and Parrot stuff removed (don't look at the missing volume knob - I don't know where it went...........
