Author Topic: Pot Hole Damage  (Read 5675 times)
stevetreacy
  • MY01 95 V6 Griffin
Pot Hole Damage
« on: 03 April 2013, 06:50:04 PM »
Hi All,
I think the old gals suffered some pothole damage. I get a knock whenever R/H front wheel hits a bump. All looks OK and tight. Suspension bounces and settles perfect and still handles as normal. Any pointers on where to look more closely.
thanks
steve
Steve440
Re: Pot Hole Damage
« Reply #1 on: 03 April 2013, 07:34:20 PM »
Anti roll bar drop links.
You will need to jack the car up and let the suspension hand to see if the joints are starting to get loose.
I had the same noise on my Aero, no obvious ware but once removed it could be clearly seen.
Steve
stevetreacy
Re: Pot Hole Damage
« Reply #2 on: 03 April 2013, 08:17:08 PM »
Hi Steve,
Uprated links ordered from PFS. Wanted these anyway.
thanks
steve
stevetreacy
Re: Pot Hole Damage
« Reply #3 on: 06 April 2013, 07:02:27 PM »
Hi All,
Well after 5 hours of painful spannering ive replaced my droplinks with uprated ones from PFS. Has cured knocking and handling seems much sharper, with less roll, which for a griffin isnt a bad thing. Tyre rotation also done now its time to get polishing. Thanks for your pointer Steve, n/s had excessive wear in top and o/s half of the insert was gone. Both top gaiters shot.  Oddly the bottom joints and gaiters on both sides were OK.
steve
Re: Pot Hole Damage
« Reply #4 on: 06 April 2013, 08:25:55 PM »
I had standard ones fitted to replace mine.  The handling was improved with those.  I expect it's just the rubber bushes that do that.
