Author Topic: esp light malfunction??  (Read 7322 times)
sean treacy
  • Number of thanks: 6
« on: 13 August 2013, 01:24:02 PM »
hi all,over the last couple of days i have noticed the esp light coming on on cornering but at a moderate speed with temporary reduction in power.prior to this the esp was working fine and only working when car was pushed especially when wet..any pointers on this one???
Re: esp light malfunction??
« Reply #1 on: 13 August 2013, 06:54:44 PM »
Check that the abs sensor rings aren't cracked or damaged is the obvious one.
sean treacy
« Reply #2 on: 13 August 2013, 08:06:30 PM »
thanks audax i will check the abs rings at the weekend,just a thought  but i did notice when got home today the n/s front tyre was down to around 15psi,could this affect the way the esp would work?
« Last Edit: 13 August 2013, 09:03:57 PM by sean treacy »
« Reply #3 on: 13 August 2013, 09:12:05 PM »
Could well do, especially with it being that low. Pump it up and find out!
sean treacy
« Reply #4 on: 15 August 2013, 02:12:18 PM »
just to let you all know.i pumped tyre back up and problem solved as in no esp light on cornering.just goes to show how sensitive the esp must be,now to find out why tyre went so soft so quick. ;)
stevetreacy
  • MY01 95 V6 Griffin
« Reply #5 on: 16 August 2013, 07:31:32 PM »
Hi Sean,
Thats good news. At least you know ESP works OK. Youve probably got a slow puncture.. LOL. See you soon.
steve
