Author Topic: A Bad Monday Afternoon!  (Read 16455 times)
Paper Plane
Re: A Bad Monday Afternoon!
« Reply #15 on: 14 October 2013, 08:24:27 PM »
16 pin connector behind the cover under the steering wheel. Flap in panel in 9-5.  Just the cover in the 9-3SS.  Not sure about the OG9-3, but in the same area.
Some other makes of car have them in the centre console or behind ashtrays etc.
Thanks!
steve
mikeloadsasaabs
  • Number of thanks: 23
« Reply #16 on: 17 October 2013, 11:05:47 AM »
I have got one of these, http://www.ebay.co.uk/itm/Vgate-Scan-VS600-Any-Car-OBD2-EOBD-CAN-BUS-Fault-Code-Scanner-Reader-Tool-UK-/321223792680?pt=UK_Diagnostic_Tools_Equipment&hash=item4aca6e1828
Just ordered one of these Steve, thanks for the link. Bought it from a different seller. I looked as the one you have as well Will, but the delivery lead time was too long as it was coming from Singapore.
« Reply #17 on: 17 October 2013, 11:51:15 AM »
It states that it can read the manufacturer specific codes.  Mine doesn't. Well it doesn't read the aircon ones, or the parking sensor ones, etc.
it would be interesting to find out which codes it can read.  Although I'm not wishing a fault on you so that you can find out....
mikeloadsasaabs
« Reply #18 on: 17 October 2013, 05:07:01 PM »
That was part of my bad Monday afternoon! I pulled the fuse to turn the EM light off, but I'm hoping there's a stored code. Having had the light in May as well, I thought it was about time to buy a reader!
mikeloadsasaabs
« Reply #19 on: 26 October 2013, 11:51:01 AM »
The light came back on at Dunkirk ferry port yesterday evening on the way back to blighty >:( Luckily, my new code reader was waiting at my destination address (my parents) that I'd ordered 10 days ago. Really easy to use, only needed a cursory glance at the manual. Anyway the code was P1181, which is to do with long term fuel/air mix too lean. A bit of googling showed that it it most likely to be an air leak somewhere in the intake system, or at least a hose on the inlet side somewhere. It also mentions the possibility of a MAF sensor problem. Embarrassingly stupid question, but never had any problems like this before, I'm assuming it's the big alloy thingie just behind the drivers side headlight?  :-[ :-[ :-[  I've cleared it for now, be interesting to see if it reappears.
Interestingly, this is the same code that was thrown in May when we got to the UK, and was cleared at the time. It seems to have taken 5 months to reappear so perhaps not a big deal? I'm wondering if it's something to do with the long fast thrash across Europe, although to be fair I was only pottering the other day when it popped up.
Steve440
« Reply #20 on: 26 October 2013, 01:57:25 PM »
I am glad you like your new code reader, they do seem to work well for such a cheap device.
It might be worth monitoring the lambda's with the live data, it might show something up or maybe even a lambda going off a bit?
Watch how quickly they react, if they are slow this is often a clue they are getting tired.
Steve
