Author Topic: Lambda life?  (Read 8749 times)
Steve440
Lambda life?
« on: 15 April 2014, 08:34:21 PM »
What is the general consensus of the life of a Lambda sensor.
I have found several references on the web saying they should be replaced at 70k to 100k.
I understand they get slow or can even fail but what mileage do ours last?
Re: Lambda life?
« Reply #1 on: 15 April 2014, 08:55:25 PM »
They will lose performance from around 100k, I replaced one on a 9-5 and got around a 5-10% improvement in fuel consumption but nothing in another car.
If you do buy one get a bosch direct fit replacement but do not buy from powersparks on ebay as they are what I would describe as a bunch of clowns, although, that's offensive to clowns.
mikeloadsasaabs
  • Number of thanks: 23
Re: Lambda life?
« Reply #2 on: 16 April 2014, 11:41:04 AM »
Hmm, do you think replacing them now is a worthwhile expenditure at 209k? Or should I just add it to the list of possible failure items that you kindly noted a couple of months ago for me Audax  :P  ;D
Re: Lambda life?
« Reply #3 on: 16 April 2014, 12:00:05 PM »
At 209k I wouldn't worry too much depending on if you will keep the car or not. ;D If you want to replace everything to try and keep fuel economy up and avoid breakdowns then the list would be for a petrol 9-5, complete service, gearbox oil change (if auto), front lambda sensor, engine temp sensor and thermostat, crank sensor and all vacuum hoses, along with the good spare DI in the boot.
A new (genuine/bosch) lambda, crank sensor and temp sensor/stat should cost less than £130 if you shop around.
Re: Lambda life?
« Reply #4 on: 16 April 2014, 01:02:25 PM »
I think circa 100k is the norm but you can sometimes breath new life into an old one by heating it to an orange glow with a blowtorch for a few minutes, which burns off deposits that impede operation.
Steve440
Re: Lambda life?
« Reply #5 on: 16 April 2014, 04:40:21 PM »
Does it make much difference if the car is mainly used for short trips?
Re: Lambda life?
« Reply #6 on: 16 April 2014, 06:27:36 PM »
I have no idea and I'm not sure how you'd tell in the real world... I have known them to fail after what I presume is contamination from oil/coolant when a head/turbo has blown.
mikeloadsasaabs
Re: Lambda life?
« Reply #7 on: 16 April 2014, 07:37:36 PM »
Mmm, well an auto fluid change is scheduled for 225k  ;D. I replaced the thermostat last year, the vacuum hoses are a bit ropy (just replaced one that had actually broken), and it had a new DI last January. So looking reasonable if you discount the ratty exhaust  ::)
