Author Topic: 9-5 brake pipe replacement  (Read 4435 times)
dave225
« on: 30 April 2014, 07:23:52 PM »
Does anyone know if you can replace the brake pipe runs under the floor (front to rear) without removing the fuel tank?
Is there a connector at the front bulkhead area or do the pipes run right up to the ABS unit?
At the rear I'm hoping they run alongside the front of the fuel tank and end in a connector near the front of the trailing arm.
Any info would be good. I've got to renew them somehow, by this summer.
Many thanks
Re: 9-5 brake pipe replacement
« Reply #1 on: 30 April 2014, 08:33:14 PM »
You can replace them without removing the fuel tank but it's actually more difficult than lowering the tank for access.
