Author Topic: buying advice  (Read 5687 times)
firemoth
buying advice
« on: 15 May 2014, 06:59:12 AM »
Hi I'm here as a prospective owner. I'm going to look at an early 5 door hatch 2.2d on Saturday. It's a high mileage but full mot and very extensive service history so I'll give it the opportunity. Never really looked at Saab's before although I've always had a quiet admiration for them. I know they're related to the vectra, of which I've had one (a 1998 model) but not anything else really. What common faults etc should I be looking out for? Also, Towbar fitting, is it complicated? Wiki said it's "Towbar prepared". What does that mean? Thanks. James
Re: buying advice
« Reply #1 on: 15 May 2014, 10:09:45 AM »
The Vectra links are somewhat exaggerated. There are a few common parts, but it's in a similar way that VW, Skoda, Audi, Seat & Bentley are "the same".
The 9-3 used the floor pan of the Vauxhall, but they used a higher strength steel.  The rear suspension is completely different, it's passive steering.
We have a very early petrol model.  It's almost 12years old and it's fine.  No rust.  Everything still works.  We have had it over 10 years with no serious problem.  The only major repair being a new steering rack, probably worn out by the car spending most of its life being driven around locally in the urban environment with few long runs.
Check the front springs are not broken.  They corrode and the bottom few inches snap off.  Check the seat belts retract easily, they get "tired".  Check all the electrics work, especially the windows and doors.  That's about it.
The 2.2 diesel does have an odd fault.  The rubber fuel lines by the injectors can go porous and leak air into the system.  This results in poor starting, especially if the car is parked with the nose pointing uphill!  Not too expensive to fix.
The electronic stability system works the rear brakes more than you would expect.  Pads wear quickly. Sometimes the calliper on the rear seizes up and needs replacing.
If it all works now, it should be good.
  • Number of thanks: 22
Re: buying advice
« Reply #2 on: 15 May 2014, 08:53:15 PM »
Firemoth says it's a five door hatch - would that be a "Classic 9-3/GM900" ?
Re: buying advice
« Reply #3 on: 15 May 2014, 11:29:36 PM »
I did wonder, but then I saw which forum he posted in.
nigsy
Re: buying advice
« Reply #4 on: 19 May 2014, 04:57:18 PM »
As someone who owned a 2003 2.2 diesel Vector; I personally would steer clear of it!
Mechanically sound; never cost me a penny; but I just found the engine a real pig. Fuel consumption was never good - At best 45mpg at worst 35mpg. When I can get 35mpg out of my 2ltr Aero Turbo now; I know which one I would choose!
It would probably be a steady car for towing though; loads of torque.
