Author Topic: 9.5 Wiper arm lengths  (Read 17558 times)
Re: 9.5 Wiper arm lengths
« Reply #15 on: 11 February 2015, 05:32:03 PM »
Thanks David.
They actually look neater than my Bosch ones - looks like they sit much lower down.
May get a pair at that price it wouldn't matter if they didn't fit
David
  • Number of thanks: 13
« Reply #16 on: 12 February 2015, 11:42:30 AM »
Hi Jim
I must admit I cannot fault them, They wipe silently and with no smears.
One thing I did notice was SAAB not listed on the back of the packaging, but don't be put off!
So impressed I got a set for my 4x4 and got the same results. For £3 each you really cannot go wrong.
They also come with a selection of optional fittings for other cars.
HIGHLY RECOMMENDED
« Last Edit: 12 February 2015, 02:29:40 PM by David »
« Reply #17 on: 12 February 2015, 03:58:37 PM »
Thanks David. I shall get a set even if kept as spares
Thanks for advice
« Reply #18 on: 14 February 2015, 05:07:12 PM »
I saw them today, it looks like the £3 price is a special offer so may disappear at some point.
I was certainly happy with them (I think I might have slated them before but actually looking at my records they were on the car for way longer than I realised!) just when they died they went from working OK to broken/split rubber in a few weeks, which compared to the Bosch which lasted longer when they failed they just got worse and worse at clearing the screen but never split.
David
« Reply #19 on: 16 February 2015, 11:59:33 AM »
Audax, from memory they are normally £4 each, but as they say 'every little helps'!  :)
The wipers appear to have been redesigned as they are not as clumsy as the old Tesco set I replaced them with. I guess time will tell.
David
« Reply #20 on: 22 February 2015, 11:48:21 AM »
A bit of an update.
Wipers are now back to £4 and......
..... the 'end' disappeared off one of my wipers. Not sure if it was whilst driving or cleaning.
This keeps the aerowingthingy on the arm, so I took it back to Tescos and they replaced it without any problem.
Did check the ends on the other wipers and they seem secure, so I am putting it down to a badly fitted 'end'. Might be worth double checking yours if fitted.
warmrain
« Reply #21 on: 06 March 2015, 01:58:43 PM »
Thanks for the tip on Tesco unibody wipers.
I got myself a 22 inch one (and Saab IS listed on the box of that one) but have to say I found it really difficult to fix it onto the wiper arm though.  There is not enough clearance to get the U-shaped thing on the end of the wiper arm to slide over the plastic clip and I was about to return it to Tesco but only persevered because at least one person on this forum had clearly managed to get it on.  I suceeded in attaching it only by first partially taking out the plastic clip halfway, positioning the U-arm in place and then jamming the plastic clip back into the curve of the "U".
Another tip : Re REAR WIPERS :--
I found it really difficult to get rear wiper blades for my 9-5 Estates.  NEO don't stock them, many autoparts shops don't have them and I suspect that Saab Orio parts will charge a bomb for them if they do supply them.  However, although Halfords strenuously claim not to stock them for Saabs, their own (Halfords) brand 14" rear wiper (code no. "W36") WILL fit 9-5's of 2006 onwards.  You have to get the one with a "stepped" slot in the wiper body as Halfords actually make 2 different types, but confusingly pack them both in the same box!
The Halfords 14" wipers will NOT fit pre-2006 9-5's because the cut-out slot in the wiper body is too short to accomodate the projection on the end of the older wiper arm. I had to insert new rubbers instead into my old original wiper blades.  Further tip -- when inserting the rubbers, insert just the rubber strip first almost all the way and THEN slide in the two metal stiffening strips (after giving them a pre-bend convex OUTWARDS from the line of the rubber, for tension and a clean wipe). I intially tried inserting the rubbers with metal strips pre-loaded and struggled!
Regards
WR
David
« Reply #22 on: 06 March 2015, 02:23:14 PM »
Hi WR
I must admit, I am a bit surprised you struggled with the wipers,  the Tesco ones fitted really easily on mine without any need to take anything apart.
Perhaps you have slightly different wiper arms or you had one of those 'one step forward, two steps back' type of days  ;D
mikeloadsasaabs
  • Number of thanks: 23
« Reply #23 on: 06 March 2015, 06:39:11 PM »
Tesco ones don't seem to be available ATM, thought I might buy a pair for the store.
I don't find the Bosch ones particularly long lasting, although I generally reckon to replace my wiper blades every 12 months anyway, which is around 17,000 miles for me. The best wiper blades I've used were genuine Saab ones, 2-3 years ago there were some on Ebay from a Saab dealer at £9.95. I've never tried the flat ones, there seemed to be good and bad reports on them, so I've stuck with the tried & tested traditional type. But at £4 the Tesco ones looked worth a punt. I will be in the UK again in a couple of weeks so I'll pop into the nearest superstore then.
