Author Topic: sudden loss of power  (Read 5105 times)
weetabixface
  • '58 9-5 Aero Estate
« on: 28 March 2015, 05:08:44 PM »
Today i had one of those scary moments, accelerating along a slip ready to pull onto main carriageway , sudden loss of power, engine light on, turbo gauge up in the red, then oil light on, praise to the baby jesus that there was a bail out lay-by
there is oil in it, it is a little darker than I would expect, was changed last August and done ~2000 miles since
where should i be looking and should i be concerned about my bank balance
cheers
W
Re: sudden loss of power
« Reply #1 on: 28 March 2015, 10:17:19 PM »
Just cut out?
If the engine has just cut out with no knocking, It may be and electrical fault.  But I think you must get the codes read.  Otherwise it's just guessing and that can get expensive.
The turbo gauge is driven by the ECU, so something must have confused things there.  Maybe an ECU failure.
If oil light is on, and no death rattle, it may just be that the ignition failed and stopped the engine.
weetabixface
« Reply #2 on: 07 April 2015, 02:38:02 PM »
codes suggest it is MAF related so will see how switching the sensor goes
W
weetabixface
« Reply #3 on: 10 April 2015, 10:19:30 AM »
MAF sensor swapped and all is good again, actually feels a bit pokier than it did in the run up to it dying on me
W
