Author Topic: CEL  (Read 5348 times)
CEL
« on: 27 February 2016, 02:41:23 PM »
CEL came on in the week on the M40. Solid, not flashing. No symptoms, no limp-home mode or anything, but I eased off a bit and got home ok. I very much prefer to use Saabtech Welwyn than the local options, but it's a 70-mile drive - is it reckless to do that with the CEL on, or ok given that there don't seem to be any accompanying dramas?...
Re: CEL
« Reply #1 on: 27 February 2016, 03:29:24 PM »
I'd happily drive with a check engine light to get diagnostics if it wasn't flashing and as long as I'd done a quick check under the bonnet to make sure it all looked OK, I'd also make sure I had a spare DI cassette and means to change it!  ;)
Re: CEL
« Reply #2 on: 27 February 2016, 11:36:38 PM »
A check engine light is an ODB2 failure. Error code should be readily readable by a generic code reader.  Buy one and read the code.  You will be quite unlucky to have an engine light caused by an error that doesn't show a generic code.
Tell us the code and we can tell you the fault.
Much cheaper than the cost of fuel to Welwyn! :)
David
  • Number of thanks: 13
Re: CEL
« Reply #3 on: 29 February 2016, 10:51:23 AM »
I ended up buying a cheap £10 code reader off Amazon ( U480 Obd-ii OBDII OBD2 EOBD Diagnostic Code Scanner CAN-Bus Trouble Code Read Diagnose Tester Diagnostic Scanner ) which is one hell of a long name but simply plugged in and gave me the codes. Well worth the peace of mind IMHO.
« Last Edit: 29 February 2016, 01:47:36 PM by David »
Re: CEL
« Reply #4 on: 02 March 2016, 02:32:20 PM »
Thanks as ever for your replies gents... Just to close the thread, I risked it. Tech 2 disclosed a 'by pass performance issue'. Some new vac hosing while I waited and all sorted.
[There's a lovely old 96 inside for sale...]
I really must get me a cheap OBD though, yes.
